Home > Technical (L322) > Parking Sensor Control Unit
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Does anyone know which wires should supply the power to the Parking Sensor Control unit?
IID Tool is reporting that it cannot find the unit and swapping it for another doesn't seem to have helped.
Thanks.
Post #672350 30th Aug 2023 7:59pm
JayGee
If it's failed it won't be recognised by the system. Take it apart and check for water ingress/ damage.
 2012 TDV8 Vogue (L322)
Post #672355 30th Aug 2023 8:06pm
Mike Edwards
The replacement unit I purchased on eBay also didn't work and there was absolutely no corrosion in that one.
Post #672359 30th Aug 2023 8:20pm
JayGee
I could never get any used modules to work on mine ( have a stack of them) and ended up buying a new one. AFAIK once it's been used on the newer vehicles it gets locked to the VIN and can't be used on other vehicles but this may be wrong as someone has said they got one working this way. 2012 TDV8 Vogue (L322)
Post #672400 31st Aug 2023 8:39am
Mike Edwards
Anyone got any idea about which wires supply power to the Parking Control Unit? Thanks.
Post #672730 5th Sep 2023 11:34am
JayGee
There's a wiring diagram in the workshop manual you can download from the Wiki. I looked at this as well when mine stopped working but it wasn't the issue. 2012 TDV8 Vogue (L322)
Post #672780 6th Sep 2023 12:23am
