Home > Technical (L322) > ZF 8 speed 8HP70 seal kit? Part numbers?
garyRR
Next upcoming item is a transmission service.
I get no issues with my box, so I'm planning a straight drain, filter change, new fluid and seals.
However, when I had my 3.6, there was a seal kit available for the 6HP. Having searched quite widely online and in ZF's product catalogue, there are no part numbers listed for either a seal kit or the mechatronic sleeve, and if I search Google, whatever comes up is always for the 6HP and not the 8HP.
Are these non-service items on the 8HP? Or does someone have the part numbers or a link to the appropriate kit(s)?
Genuine ZF filter and Lifeguard 8 ordered Thumbs Up
I'll of course write a guide. I have the photos from when I did the 6HP also, so can write a guide for both. 2015 Range Rover Autobiography 4.4 SDV8
Post #672692 4th Sep 2023 3:31pm
RRPhil
The ZF part no. for a ZF 8HP70X oil change kit without oil is 1087 298 365, and with oil it’s 1087 298 364. The kit includes the plastic sump/filter, screws & filler plug, but not the Mechatronic sleeve.
Land Rover sell a ‘plug service kit’ p/n LR023292 which includes the Mechatronic sleeve as well as the plugs, and also the plastic sump/filter & screws p/n LR065238
Regarding the seals, because the 8HP70 has a chain-driven vane pump the connections between the Mechatronic unit and the pump and casing are quite different to the 6-speed e.g. separate sleeves for the pump inlet and outlet. I would avoid disturbing this if I were you.
Phil
Post #672697 4th Sep 2023 6:09pm
garyRR
I've ordered 1087 298 364 with the oil.
Is the mechatronic sleeve from the 6HP the same? Seems silly to have to buy a kit with plugs you already have. 2015 Range Rover Autobiography 4.4 SDV8
Post #672706 4th Sep 2023 9:11pm
garyRR
I've ordered 1087 298 364 / 5 with the oil.
Post #672707 4th Sep 2023 9:11pm
RRPhil
No, I'm afraid the sleeves are different. 6HP = 0501 216 272, 8HP = 0501 220 929.
Phil
Post #672710 4th Sep 2023 11:09pm
