Home > Technical (L322) > Fuel filter.
KitTheRam
United Kingdom 2009 Range Rover Vogue TDV8 Santorini Black
Fuel filter.
Apologies for a very basic question.
I had a service last year in which the fuel filter was changed, I’ve only done about 3/4 thousand miles in it since. Is this a yearly service item on these cars or is it a once every 2 year thing at my sort of mileage as per the general info about fuel filters online?
Used a bit of additive etc over the year so maybe full of crap now if it worked!
Lastly I am guessing a Febi / Britpart filter has no real difference to the oem one?
Also I remember someone saying they are the same filters used on transit vans… 2009 pre-facelift 3.6 TDV8.
Post #673409 15th Sep 2023 11:57am
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
I change every 3 year due low milage, 10 000km/year.
Post #673418 15th Sep 2023 2:18pm
pjw888
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
Hi, doing that mileage I'd change every couple of years. I'm a low mileage user but do mine every two years to be safe. I use genuine and or OE spec only. I've had some bad experience with some but not all Britpart parts so choose more carefully now.
Post #673446 15th Sep 2023 6:59pm
KitTheRam
Thanks, guessed that was the case but wanted to check.
Last time I went with a Febi branded one which is a brand I trust and use across my cars for when I feel the oem prices are just too high.
Oil wise I’m sticking to the correct Shell Helix and a Mahle filter. 2009 pre-facelift 3.6 TDV8.
Post #673451 15th Sep 2023 7:50pm
garyRR
I personally consider Febi far superior to Britpart. Most car parts may be similar in quality of design and materials used (even including genuine), but the quality control I would say differs vastly.
And for your mileage, I'd probably change the filter every 3 years (I believe the service book says 2) and save a bit of cash. 2015 Range Rover Autobiography 4.4 SDV8
Post #673460 15th Sep 2023 10:05pm
KitTheRam
Good to know.
I can’t say I have ever bought Britpart but noticed many places stock their L322 fuel filter so thought I’d mention it. Febi always seems to fit exactly like an oem part I find, especially on my bmw e34 touring.
While on the subject of service items, this car is my first Diesel, what are the general thoughts on glow plug changes? I have a full main dealer history file so could go looking for when they were last changed.
Guessing it’s not a job that has to be done too often? 2009 pre-facelift 3.6 TDV8.
Post #673491 16th Sep 2023 11:03am
garyRR
I doubt you'll ever need to change the glow plugs - theyll most likely exceed the life of the car, so only change if there's a fault. Key things with the L322 diesels are keeping on top of oil changed. A strict 5,000-7,500 mile interval. 2015 Range Rover Autobiography 4.4 SDV8
Post #673528 16th Sep 2023 8:18pm
DrRob
I change all filters annually. Generally use Mahle ones from Advanced Factors.
https://www.advancedfactors.co.uk/kit114-m...9816-p.asp Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #673529 16th Sep 2023 8:28pm
