![]() | Home > Maintenance & Mods (L322) > 3.6 TDv8 Coolant leak |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 710 ![]() ![]() ![]() |
Any pointers please ?
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
I'd have a look around your thermostat housing, which is well known on the 3.6 to fail along the plastic weld.
KF
When I did the thermostat housing, it was about £110 for the genuine housing from Land Rover. Given they're plastic welded, I'd be very wary of aftermarket, if even available.
Thanks Gary,
Well, that was a surprise !
If your thermostat housing is good, leave it be.
OK !
Get yourself a good set of extended hose clip pliers, plus a ratcheting pair also, such as the below items:
Just to close this discussion off :
