Home > In Car Electronics (L405) > TV tuning
j_rov
TV tuning
First world problems and all that, but how do I tune the DAB and TV stations on a touch pro system (MY18)?
Many of the displayed channels say No Signal.
Thanks __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #674264 25th Sep 2023 11:01pm
Arch Stanton
you may have a dying aerial amplifier, this happened on my old BMW and I gradually lost channels/signal became weaker, an new amp sorted it. Have you read any codes? Onto my 2nd FFRR, this time an L405 5.0L SC AB in SVO Palette black.
Post #674275 26th Sep 2023 8:52am
j_rov
What i mean is that a lot of the channels are from the locality of the previous owner - BBC Sheffield etc. I'm in the midlands and those channels are never accessible from here, even on a standard domestic TV.
Seems likes it just needs a retune, but i cannot see any menu option for it. __
Land Rover History:
1976 Series 3 2.25
Post #674279 26th Sep 2023 9:30am
try pressing 'find', this should list available channels.. ... - .- -.
Post #674297 26th Sep 2023 11:30am
j_rov
It shows hundreds of channels, most of which I cannot tune to. __
Land Rover History:
1976 Series 3 2.25
Post #674298 26th Sep 2023 11:39am
its also worth mentioning that the FF's tv tuner isnt the best....most houses have rooftop aerials to get a good stable signal...
i would move to a high location or one that you know has a strong digital signal.. ... - .- -.
Post #674305 26th Sep 2023 12:15pm
James W
Saudi Arabia 2017 Range Rover Autobiography SDV8 Siberian Silver
The user manual says "The TV system is continually checking the availability of channels. Channels in the list may not actually be available. For example, when driving through different transmitter regions."
I can't see any advice on how to delete old channels and start again. My advice would be to find the ones that do work, and that you want to access, and add these to your favourites list. Go to a channel and press the 'star' icon to add it to favourites.
When you go into the "Favourites" list, the manual says "To rearrange the order of the list, touch the edit icon in the footer. Drag and drop selected items to the desired position. Press OK to confirm." FFRR SDV8 Autobiography
Post #674313 26th Sep 2023 1:17pm
j_rov
Thanks, will give it a go! __
Land Rover History:
1976 Series 3 2.25
Post #674346 26th Sep 2023 10:42pm
