Home > Technical (L322) > Door sensors and ECU switch-on
DeeJay
South Africa 2011 Range Rover Vogue SE TDV8 Fuji White
I am (somewhat) determined to make sure the ECU does not switch on every time i open one of the doors. Especially for upcoming overland trips where you live out of the car and open the doors so many times a day I am just very worried that the battery will go flat and I am stuck in the middle of the Namib.
Surely the ECU will be triggered by the door sensor, I reckon if I can trick the car into thinking the doors are always closed then my problem is solved. This car does not have a sensor with a pin that I could tape down, in fact I cant find it anywhere or any information from my quick searches.
How does the door sensors work on these?
Where are the door sensors located?
Could I isolate them temporarily?
Should I try a different method?
Am I unnecessarily worried about this?
2011 4.4 TDV8 here. 2011 Vogue SE 4.4 TDV8
Post #674376 27th Sep 2023 11:55am
from memory when you unlock the doors, the lights come on so they must be linked to the 'unlocking'
you can disable the interior lights if you are constantly opening and closing the doors.
i dont think theres a way to stop the FF from waking up on the door opening.. ... - .- -.
Post #674384 27th Sep 2023 2:20pm
DeeJay
Lights can be disabled/enabled by press+hold the light switch ...it gives a flash and then they dont come on for unlock / door open.
...ive already done this. Next step... the ECU!! 2011 Vogue SE 4.4 TDV8
Post #674386 27th Sep 2023 2:24pm
you could put an inline switch from the battery so you can disable all the electrical systems.. ... - .- -.
Post #674387 27th Sep 2023 2:33pm
mjdronfield
The door latch itself contains what tells the car the door is open I believe.
But if you disable it, your alarm won’t sound if a door is opened… the interior light won’t come on, suspension might keep moving when you get out.
That said, non of the above is worse than a flat battery.
Folk have fitted a second battery in the boot to help, but you prob already know that
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #674389 27th Sep 2023 3:12pm
mjdronfield
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #674390 27th Sep 2023 3:19pm
