![]() | Home > Maintenance & Mods (L322) > Powering the FBH directly from a second battery - thoughts ? |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 303 ![]() ![]() ![]() |
So my FBH works both manually from the LCD and from the remote.
Hi @JayGee, I’ve found that I’m not able to charge using the big power cable going to the boot fuse box with my CTEK. I guessed this was down to the BMS. That put me off when I was considering the standard second battery set up because if the CTEK won’t work as a supply there then why would a second battery.
Its not the BMS that shuts down the FBH, its the low voltage threshold setting in the FBH itself.
Thanks for the tip @Phoenix ; I’ll take a look at the unit and the fuse box over the next week or two. That’s certainly step 1…. Much cheaper than a DC-DC smart charger and an additional lithium battery. TDV8 4.4 2012 |
If you are able to backprobe the FBH power connector, put a voltmeter between the FBH +ve and the battery +ve, then fire up the FBH, you'll be able to see what the volt drop is, and if it's the cause of the issue before you get b@lls-deep in the wrong direction... It'd be worth repeating the measurement on the -ve side as well.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
I would say my battery is about 5 years old and I don't get a problem with the FBH shutting off early. Is it a voltage issue I.e. could you run a test by connecting an external power supply (a 12A charger would probably be sufficient) and then testing to see if the FBH is still cutting off early, even though you should have a steady voltage? 2015 Range Rover Autobiography 4.4 SDV8 |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
I had the same issue of too early shut off due short trips.
