![]() | Home > Technical (L322) > 2002 4.4 V8 (M62TU) ticking noise from engine |
Bas1985 Member Since: 11 Jun 2023 Location: Houten Posts: 11 ![]() ![]() ![]() |
Hey all. My 2002 L322 just passed its Dutch MOT with just a headlights adjustment being needed (so happy after all the work I put into it). The mechanic did note that there is a too loud ticking coming from the top LH side (seen from within the car) of the engine. I did my timing chains etc two weeks ago and this noise only started appearing this week.
So I pulled the valve cover and don’t see or feel anything that is obviously loose. Also checked the chain tension and am wondering if this is not too loose?
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3261 ![]() ![]() ![]() |
Vanos? |
batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 208 ![]() ![]() |
Hydraulic lifters ?
Thanks for the input, those are definitely two to consider.
may be something simple like the fan, hitting the shroud or loose shroud etc. |
