Home > Maintenance & Mods (L322) > Painting Scuttle Panel - Advice Sought.
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
Right, I've had enough of my scuttle panel turning white every few months - even after using expensive trim restorers (as recommended on here).
So I'm going to paint it. Can't be a**ed to remove it, so will paint it in-situ.
Can anyone recommend which paint I should use please? What about Humbrol Enamel paint? It's used for painting plastic models so would it work on a plastic scuttle?
Any advice gratefully received.
Post #675092 8th Oct 2023 1:31pm
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Cant help with recommendations, but will follow this as I want to do mine Thumbs Up
Post #675093 8th Oct 2023 2:24pm
I used this trim restorer on mine a few years ago and surprisingly it is still black.
On this basis l could recommend it. Thumbs Up
Post #675100 8th Oct 2023 4:16pm
supershuttle
http://www.fullfatrr.com/gallery/albums/us...C00622.JPG
I just got my local bodyshop to do the bonnet vent (when I had an L322) but I just tidied up the scuttle. Every time I look at a picture I wish I still owned that car. Geoff
Post #675107 8th Oct 2023 6:12pm
All I'll say is it will take less time to remove it than it does to mask it up, you will also get a better job done off the car. If you do do it on the car don't forget to put paper under the vent, inside the bonnet....
Read this for tips....
https://www.fullfatrr.com/forum/topic27260.html
Thumbs Up Pete
-Click here for Thread-
Post #675112 8th Oct 2023 8:31pm
gettingold
Re: Painting Scuttle Panel - Advice Sought.
As a model maker I wouldn't use the Humbrol enamels as I think it would spider Web crack on you. I can't recommend any other paint though. There's got to be something out there....
https://www.google.co.uk/search?q=aerosl+s...nt=gws-wiz Hunt for a L405 is on.
Post #675121 9th Oct 2023 6:04am
Gyre8
OK, thanks for the comments all. I have decided to take @nicedayforit's suggestion and give trim restorer one last try.
Before and after pics to follow....
Post #675243 10th Oct 2023 1:36pm
DanRRL322sc
How did this work out? I too am fed up with the light grey/white plastic look that returns every 3-4 months after using plastic trim restorer on it!
Post #682485 12th Jan 2024 10:27am
Gyre8
Not done yet Dan. Life intervened. Will be done on the weather-acceptable day.
Post #682506 12th Jan 2024 2:57pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
just to show I understand that it's not done yet Laughing
Post #682525 12th Jan 2024 5:24pm
