Home > Technical (L322) > Height sensors - JLR or?
JayGee
Got an intermittent Adaptive dynamic fault on the front left sensor which may be wiring but I'm more leaning towards it being the sensor so am going to replace it unless I see anything obviously wrong with the wires when I take a closer look. I'm also minded that having a spare front and rear available is a wise investment. I can go with JLR but are there any others that do the job as well ( not Britpart) as I assume JLR don't actually make these? 2012 TDV8 Vogue (L322)
Post #675126 9th Oct 2023 9:45am
mjdronfield
I think the consensus on here is that it’s best to go JLR with height sensors. Replaced a genuine one like for like on mine last year and no further issues.
Maybe it’s more of an issue if you mix genuine with non genuine, but I don’t think they are daft expensive.
The original height sensor wiring is separate to the adaptive dynamics wiring on the L322. That’s why there are 6 pins. 3 for each. So you could have issues with AD and the air suspension operating fine. It wasn’t till the L405 that they combined the systems properly and they went back to 3 connections. That’s my understanding anyway.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #675128 9th Oct 2023 10:25am
Goldstar
2011 Range Rover Autobiography TDV8 Stornoway Grey
After market ones seem to work ok but are a pain in the a$$ to remove so for that reason alone the next time I replace one it will be genuine OE Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey.
Post #675129 9th Oct 2023 10:46am
JayGee
Genuine ones it is then Thumbs Up 2012 TDV8 Vogue (L322)
Post #675130 9th Oct 2023 11:16am
