Home > Technical (L322) > Gap IID tool
Tomwesty
Gap IID tool
Is it possible to identify the soot level in the DPF by using the GAP IID tool and if so how?
Post #675582 15th Oct 2023 2:38pm
JayGee
Yes it will give you an inferred level based on the differential pressure across the DPF. It's not an absolute level as it also depends on other factors. 2012 TDV8 Vogue (L322)
Post #675583 15th Oct 2023 2:49pm
