Home > Maintenance & Mods (L322) > ABS Sensor broken
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
ABS Sensor broken
I have been dismantling the front suspension today to change the wheel bearing and found that the ABS sensor was rock solid, it promptly snapped off once a bit of persuasion was applied... Whistle
Is it possible to drill out the sensor now I have the whole wheel assembly off and once I press out the bearing or will that open up a world of trouble?
Will
Post #675907 19th Oct 2023 6:36pm
Jamesh7216
It is OK to drill out the part that is stuck, I did it on my car, just start with a small drill and gradually increase the drill diameter, before you reach the sensor diameter you will find the remaining bit will fall out
Post #675909 19th Oct 2023 6:54pm
Red Hot one
That's great, thanks for your reply.
Thumbs Up Thumbs Up
Will
Post #675915 19th Oct 2023 7:26pm
