![]() | Home > Technical (L322) > ZF8 HP70 Torque Converter |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3336 ![]() ![]() ![]() |
They are usually very reliable and trouble free. What are your sysmptoms? 2012 TDV8 Vogue (L322) |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1342 ![]() ![]() ![]() |
Soft and sloppy and the rpm's rising while it changes gear.
Mine has a small bump 1-2 on light throttle if it's any consolation ( since day 1) but the rest doesn't sound right. Has it always done it or are these new symptoms? ZF gearbox specialist would probably be your best bet to diagnose it. 2012 TDV8 Vogue (L322) |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
That is not right for sure....I'd be seeking a ZF gearbox specialist too for a diagnosis....
It's done it, other than the noise, since I bought it 3 years ago.
To be honest I've never 'floored it' from a standstill as it's not something I'd need nor think wise on a 11 yr old car with 160k miles on it but when I have pulled away 'briskly' it's perfectly smooth. The only 'gripes' I have with my box is the occasional 1-2 bump at light throttle and a tendency to hang onto the gears too long going up hills. 2012 TDV8 Vogue (L322) |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1010 ![]() ![]() ![]() |
Jason ( and all the crew at Stephens Engineering ) are near to me - so the last 3 or 4 Range Rovers I have owned over the years have all gone to Stephens for full ZF service, cannot reccommend them highly enough, but they are a very busy workshop, so booking it in can take a few weeks sometimes.
These 8spd's are a common fit to a lot of BMW's and are well liked so may be worth doing some searches on BMW forums? 2012 TDV8 Vogue (L322) |
Ditto. Same here. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
You might want to also consider Bristol Transmissions or Dartford Transmissions and Autocare Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
