Home > Technical (L405) > Executive Rear folding seat - base
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
Hello
While unfolding the seats I saw some coins and other bits under the base of the rear seats. Is there a way to just move the base do I can clean under them?
I think I remember reading push the button and then pull a fuse at some point. But I am sure there is a better way.
Many Thanks SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #676900 31st Oct 2023 10:48am
DavyM
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
The rear seat bases of my 2020 Autobiography just pop off the mounting pegs when given a sharp pull at the front. Pre 2018 model have a couple of clips that have to be unlatched from under the front of the seat base.
I had a similar situation when I bought my car earlier this year.
Hope that helps.
Davy
Post #677510 8th Nov 2023 8:32am
luxmoggy
Thanks that worked. Just need to disconnect a cable. Is the middle base seat the same? SDV8 AB MY 2020
Post #677513 8th Nov 2023 10:23am
DavyM
I'm sure it is. Rangerover L405 Autobiography 4.4SDV8 2020
Rangerover L322 Vogue 4.4TDV8 2011 gone
Discovery II TD5 gone
Discovery 300TDi gone
Post #677534 8th Nov 2023 3:14pm
luxmoggy
It is. Coins and AirPod found. I also vacuumed under them. SDV8 AB MY 2020
Post #677537 8th Nov 2023 4:11pm
DavyM
I found a VIP pass in mine, along with the fluff and sweets. Smile Rangerover L405 Autobiography 4.4SDV8 2020
Post #677585 9th Nov 2023 7:14am
