![]() | Home > Technical (L405) > Heater blowing cold air |
| Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3284
Thermostat sticking? |
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631
Fix the coolant leak first, there's probably a vapour lock in the heater circuit or the diverter valve is not functioning correctly, but TBH, with a leak, none of the coolant circuit can be relied upon to work as intended. |
