Home > Technical (L322) > How can I run S/C without plenum attached?
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Still working on the car, and I could with running the enhine without the big plastic plenum attached.
Problem is it starts then dies when disconnected!
Any idea? I really want to see whats going on under there which I cant with the big plenum attached!
Post #677057 2nd Nov 2023 11:57am
fisha
What is it that you are wanting to see when it runs ?
Without the plenum, the engine probably wont be able to to detect air inlet pressure / air flow ... which it'll try and use for fuel injection amounts. V8 or else ...
Post #677058 2nd Nov 2023 12:07pm
philip1972
There is a coolant pipe under there that I could do checking for a leak while running.
I guess I will put the plenum on, run it and then take off again to look for coolant.
Thanks for the advice Thumbs Up
Post #677059 2nd Nov 2023 12:16pm
