![]() | Home > Technical (L405) > SDV8 gearbox kicks down too easily |
| Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 409
It is an 8-speed gearbox so it is quite easy and normal to change from 8th to 7th. Current:
| fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1561
Yeah, I’d say it was common practice. If you’re cruising and maintaining speed for an uphill it’ll hold the gear. If you want to accelerate and gain speed then it’ll drop a gear to do it. V8 or else ... |
| philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527
This is one thing I preferred on my Disco 4 6 speed to the D4 8 speed. Fewer kick downs and just used the torque. |
| Tdtj Member Since: 29 Sep 2021 Location: East kilbride Posts: 208
If I’m using mine on cruise or just normal motorway stuff and see a slight incline ahead I just flick the right steering wheel paddle to keep it in 8th gear and use the torque instead of the very unnecessary change down 2016 4.4 diesel
| Iceboy74 Member Since: 20 Sep 2023 Location: Berkshire Posts: 25
Thanks All.
