Home > Maintenance & Mods (L322) > 4.4 tdv8 2011 200000kms timing chain tensioner
Ricky-ffrr
Netherlands
Gday gents,
Want to know if someone can tell me if changing the timing chain tensioners are replaced after a certain amount of kms? Changing a couple of parts of the engine soon and would be a shame with everything more open at that point to change them.
Kind regards
searched and searched but couldnt find any answer to this question.
Post #677687 10th Nov 2023 9:29pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
Have you tried the Workshop Manual on the WIKI ?
https://drive.google.com/file/d/1ryNmV4u_t...sp=sharing TDV8 4.4 2012
Post #677693 11th Nov 2023 12:09am
Ricky-ffrr
Netherlands
Yes, I did but cant find an answer or advise on when to replace them
Post #677700 11th Nov 2023 8:48am
i found this using our search function,
https://www.fullfatrr.com/forum/topic48934...+tensioner
lots more info to be found .. ... - .- -.
Post #677701 11th Nov 2023 9:03am
Stan, I think that's for the drive belt not the cam chain... Thumbs Up Pete
-Click here for Thread-
Post #677702 11th Nov 2023 9:36am
Ricky-ffrr
Netherlands
correct thats the belt not the chains.
Post #677717 11th Nov 2023 1:00pm
Embarassed ... - .- -.
Post #677726 11th Nov 2023 5:01pm
Rambles
By timing chain i assume cam chain?
Accessory belts are at the front (2 for MY11 4.4) and are not connected with timing AFAIK
Not sure what a drive belt / chain is.
Timing chain replacement is about a 6hr job.
Normally when a tensioner needs replacement, probably the relevant chain / belt also needs replacement
Not sure on the 4.4 TDV8 if the cam chain has a tensioner
Post #677759 12th Nov 2023 9:11am
