Home > Technical (L322) > HELP! Very wired temp issue.
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Driving along, temp gauge in the middle, all seems fine.(4.2 S/C)
Suddenly gauge drops to just above blue.
Fan roaring on full.
Plug IID tool in, coolant temp steady between 80 and 90. I drive off again and Fan stops running on full speed and temp gauge goes back to normal. IID coolant temps stays the same between 90 and 90.
What the hell is going on?
Thanks!
Post #677985 15th Nov 2023 12:35pm
dingg1
Scan for fault codes when the fan is roaring
Had this issue once or twice
P0116
Changed the temp sensor, but still happens after clearing codes , key off restart and its cleared itself Confused
Post #677988 15th Nov 2023 1:21pm
philip1972
Thanks. I am getting P0151 occasionally, but I dont think thats related.
No other codes.
When you say sensor, is that the coolant temp sensor? It weird because on the return journey everything was fine, and the coolant temp via the IID is always where it should be, even when the temp gauge drops!
Post #677989 15th Nov 2023 1:39pm
dingg1
Yes coolant temp sensor, changing it out didn't sort it out for me, still happens once in a blue moon.
Happens when clearing either rich or lean codes with iid (can't remember which) but clears immediately with ignition off and restart
Post #677994 15th Nov 2023 2:18pm
philip1972
How strange!
I am going to change the coolant temp sensor and may do the oil temp sensor too-there is a post on here somewhere saying can cause the temp gague to drop Shocked No idea how but they are cheap.
Anyone else had anything similar?
Post #678003 15th Nov 2023 5:46pm
