Home > Maintenance & Mods (L322) > Bilstein CVD front shocks
Faukstad
Norway 2012 Range Rover Autobiography TDV8 Santorini Black
Does anyone know where I can get my hands on Bilstein front shocks (with bags is also an option) for a 2012 TDV8 with CVD, that cost only an arm or a leg, and not both?
Post #678344 20th Nov 2023 3:29pm
Epson Green
Is there a particular reason for wanting Bilstein?
The OE supplier for the front was Delphi who became BWI. Bilstein on the rear. Kevin
2012 L322 Westminster 4.4 TDV8
1999 P38A 4.0 SE - Sold
Post #678402 21st Nov 2023 12:09am
GraemeS
Australia
I fitted Bilstein front struts and rear shocks ex UK because they were considerably cheaper than LR ex UK although still quite expensive. The struts were fitted with Dunlop air-springs.
Post #678407 21st Nov 2023 3:22am
Faukstad
No real reason tbh, only personal preference.
Bilstein are a dedicated suspension company, only dealing with that.
BorgWarner/Deplhi make everything from clutch plates to alternators. Razz
Post #678659 24th Nov 2023 8:33pm
GraemeS
Australia
Be careful - Bilstein rear air-springs are the shorter variety used on earlier L322s with shorter rear shocks and will split open on MY07-09 TDV8 and all MY10-12 vehicles if the vehicle is used at off-road height on rough ground where the shocks can fully extend.
Post #678660 24th Nov 2023 8:51pm
Faukstad
Thanks Graeme, good tip!
I have the CVD-ones though.. I didn't know CVD was available on the earlier L322s?
I'll keep that in mind though, allthough I rarely take it out on roads so rough that I need off-road height over longer distances.
It's more of a.. "stock exchange tractor" as we call them here in Norway. Laughing
Post #678661 24th Nov 2023 8:55pm
GraemeS
Australia
Longer non-CVD rear shocks were fitted to TDV8 only versions of MY07-MY09 and all CVD rear shocks are the same, longer length.
The Bilstein rear CVDs that I fitted to mine are the same length as the original LR CVDs but Bilstein messed-up in using the original shorter air-springs so their air-springs burst.
Post #678662 24th Nov 2023 9:37pm
Faukstad
Allright, gotcha.
So no Bilstein air bags on the back, specifically then.
I can't find them anywhere, along with the front complete struts (except for silly prices above 1100 euros) so unless someone knows of a webshop that has them I guess I'll be going for the standard BorgWarner setup.
It seems like it's tried and tested though, and I bet you guys would let me know if they're not the way to go. Wink
Post #678664 24th Nov 2023 10:16pm
Faukstad
Advanced Factors only have the Dunplo rear bags.
Are they any good..?
Post #678665 24th Nov 2023 10:33pm
GraemeS
Australia
I bought genuine LR rear air-springs from Island4x4.
Post #678669 25th Nov 2023 1:05am
