Home > Technical (L322) > 5.0 supercharged smoking
William97841
Hi so got this 2009 5.0 supercharged for about 8 months now but since it’s getting cold I’m noticing the exhaust has a lot condensation coming from it even after running for 45mins. I pull up no smoke or anything about 30seconds later I’m starting to see it smoke or condense. I’ve always had diesels and never had any issues but this is the first petrol I’ve had in years lol. So is it normal? Also doesn’t burn any water or oil. Had the chains done 3 months ago as well. Thanks
Post #678870 27th Nov 2023 8:49pm
William97841
https://youtube.com/shorts/--mQno50in0?si=4pUz1Pp9r_rD0u7L
Post #678873 27th Nov 2023 8:55pm
dhallworth
Both of my Supercharged Range Rovers have done this.
Post #678875 27th Nov 2023 9:35pm
kevinp
For every gallon of petrol the engine uses a gallon of water passes out the exhaust pipe and in cold weather it shows as water vapour. I couldn't believe this when I was first told so your exhaust is basically a drain pipe. Thumbs Up
Post #678880 27th Nov 2023 10:00pm
William97841
Thanks guys at least I know it’s normal. Learn something new every day. Now just gotta tackle the supercharger knock now bloody car
Post #678957 28th Nov 2023 11:04pm
Water vapour from a petrol is absolutely normal sir... The bigger the engine and the colder the weather gets, the more condensation you will see...
And that's why you rarely change a diesel exhaust muffler, whereas petrol exhausts rot from being constantly wet!... Rolling Eyes Thumbs Up
Post #678959 29th Nov 2023 12:47am
