Home > General (L405) > Cold Weather
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Cold Weather
First cold spell since getting the L405. All the doors frozen shut. The L322 sitting next to it was fine.
Now every door I tried to open, even if it looks closed and flush with the bodywork, is showing on the dash as open so I can't lock the car.
Is this a common experience?
Post #679109 30th Nov 2023 10:56am
Never happened to mine, maybe you are just unlucky or it has rained on the 405 and it's not been driven to shed some of the water...!! Pete
Post #679111 30th Nov 2023 10:58am
Abacus405
United Kingdom 2017 Range Rover Vogue SE TDV6 Carpathian Grey
Get some Gummi Pfledge and liberally apply it to the door seals. Only once per winter season, should solve the problem
https://www.ebay.co.uk/itm/266515472464?gb...wOhAAAAAAA 2017 (67) Vogue SE Corinthian Grey
Post #679117 30th Nov 2023 11:16am
Gremlin500
United Kingdom 2017 Range Rover Vogue TDV6 Corris Grey
#2 Thumbs Up
I always ensure my rubbers are well-lubricated, then going in or coming out is never a problem! Rolling with laughter Rolling with laughter Rolling with laughter
Tailgate & bonnet also!
Warning: Do not use Gummi-Pledge in the bedroom! Shocked Laughing V6 Vogue - “Less is More” - less to go wrong!
Post #679155 30th Nov 2023 4:44pm
caymanblack
United Kingdom 2017 Range Rover Autobiography SDV8 Carpathian Grey
Laughing Laughing Laughing overfinch modified
Post #679162 30th Nov 2023 5:25pm
congratulations abacus, you're the first person to mention Gummi Pfledge this winter.. Thumbs Up ... - .- -.
Post #679163 30th Nov 2023 5:39pm
Abacus405
Thumbs Up Someone had to 2017 (67) Vogue SE Corinthian Grey
Post #679164 30th Nov 2023 5:44pm
Martin2
My L405 was the same, but GF solved the problem. Not something I’ve experienced in any other car unless super cold. MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #679168 30th Nov 2023 6:30pm
Arch Stanton
I've used a light oil on a cloth to rub over the seals and it hasn't caused any adverse issues but solved the problem Onto my 2nd FFRR, this time an L405 5.0L SC AB in SVO Palette black.
Post #679170 30th Nov 2023 6:44pm
Andy S
Gummi pfledge here too. Had all doors freeze last year, so they’ll be getting a treatment tomorrow. Bigger issue is the mini, which has frameless glass in the doors which freezes in the cold. Mrs S often forgets to put the car away in the garage and then moans that she can’t open it on a frosty morning………
Post #679174 30th Nov 2023 7:42pm
