Home > Maintenance & Mods (L322) > height sensor
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
height sensor
ok height sensor clip ................what the helll Censored Censored Big Cry Big Cry Big Cry Big Cry
i have been trying for the last hour at least to reseat the clip into the new range rover height sensor (genuine one ) and well im at a loss is there some secret range rover magic in getting these clips to seat ????? because i was ready to drive the thing into the sea Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
anybody if you know what im doing wrong shout put ....thanks
will L405 2014 Loire blue Autobiography
Post #679304 2nd Dec 2023 4:05pm
mjdronfield
Clip? The electrical connector? The bracket can be a pain….
Some plugs have 6 pins and some have 3, make sure they match.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #679307 2nd Dec 2023 5:56pm
will308f
yea the electrical connector............got the old sensor off ,new one on but the connector is another thing L405 2014 Loire blue Autobiography
Post #679309 2nd Dec 2023 8:10pm
mjdronfield
So you can’t get the connector to go into the new height sensor?
Make sure they both have the same number of pins as i imagine they won’t connect otherwise. Did mine over a year ago so can’t remember exactly, but I don’t think that was the hard bit for me, can’t remember if you have to press a clip to push it on, but don’t think so. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #679310 2nd Dec 2023 8:19pm
will308f
yea 3 pin ,there are clips to hold connector secularly on to the sensor .it just wont clip in Big Cry going to have a another go tomorrow(depending on weather ) L405 2014 Loire blue Autobiography
Post #679316 2nd Dec 2023 9:19pm
mjdronfield
Yes, best to attack it again tomorrow, snow permitting. Save getting too annoyed with it. Did you get a genuine one? Though should still fit. I think one side may have curved edges so it will only fit one way, but you will be beyond that stage I imagine…. Can’t think of anything else… sorry…
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #679317 2nd Dec 2023 9:49pm
Epson Green
Check the orientation, they only fit one way. Kevin
2012 L322 Westminster 4.4 TDV8
1999 P38A 4.0 SE - Sold
Post #679355 3rd Dec 2023 6:39pm
JayGee
They are not easy to remove and I had one that was not locked in properly which caused an intermittent adaptive dynamics fault . I blasted out the socket and plug with WD40 and got it to latch which not only resulted in no more faults but also a much smoother ride...... 2012 TDV8 Vogue (L322)
Post #679364 3rd Dec 2023 8:14pm
will308f
Yea genuine Range Rover part ,the old one was a bit to get off contacts cleaned with electrically cleaner,the contact will slid onto sensor but just won’t go in far enough for clips on the side to engage and hold in place L405 2014 Loire blue Autobiography
Post #679381 3rd Dec 2023 10:11pm
