![]() | Home > Technical (L322) > Alarm sounding and clocks (time) resetting when unlocking |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 928 ![]() ![]() |
Assuming the new battery is still healthy and fully charged, I’d try a ‘hard’ reset if not tried already, disconnect both the positive and negative cables from the battery (after waiting 120 secs. from unlocking / opening the bonnet) and touch them together for a few seconds, then re-connect everything and see how you go 👍 Jonathan
benjwom Member Since: 13 Apr 2017 Location: Sheffield Posts: 12 ![]() ![]() |
Thanks Jonathan, I will give it a try this afternoon and report back if it stops raining. I thought I had read that this only worked on the 3.6 so didn't think to try it. Current: 2011 RR 4.4 TDV8 Vogue SE
May or may not have any effect but it’s quick and free so worth a shot |
Disconnected the battery and performed a hard reset, no difference unfortunately.
Some additional info: I have just replaced the battery in the Webasto pre heater remote fob. When I turn this on remotely this also causes the alarm siren to sound and the clock to reset. Current: 2011 RR 4.4 TDV8 Vogue SE
