Home > Technical (L322) > 4.4 TDV8 Top Bleed Tube Fitting
Benji1
Australia
There is a 90 degree plastic fitting referenced PA66-GF30 on the top bleed tube on my 4.4l TDV8 that has cracked and subsequently leaking coolant. Trying to either source this part or if not replace it with a metal 90 degree fitting. Anyone know where I can find one of these plastic fitting or if not whether replacing it with a metal 90 degree will be a problem?
Photo of this unit attached.
Post #679536 5th Dec 2023 3:05pm
JayGee
You mean this
 2012 TDV8 Vogue (L322)
Post #679559 5th Dec 2023 8:17pm
Aren't those barbs facing the wrong way... or am I being daft.... Question Pete
-Click here for Thread-
Post #679561 5th Dec 2023 9:10pm
dhallworth
They do appear to be!
However, they seem to be facing the same way on the broken bit of plastic next to it. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #679562 5th Dec 2023 9:30pm
Yeah, I spent ages looking at both of them.... weird.... Pete
Post #679564 5th Dec 2023 9:40pm
JayGee
I realised it was wrong after I'd made it but couldn't be bothered to remake it as it's only a bleed tube. 2012 TDV8 Vogue (L322)
Post #679567 5th Dec 2023 10:09pm
Benji1
Australia
Thanks for this and looks like the one.
No problem it seems not to have to replace the original item here which Ive been told will take 5 weeks to source from the UK.
It actually broke from contact with the rubber engine cover which I had only just adjusted to sit level on the top of the engine. Very brittle fitting. Must have been ready to go and so happy for it to have happened in the driveway and not out on the road.
There are plenty of metal 90 degree fittings out there that I can source.
Post #679573 5th Dec 2023 11:04pm
Thumbs Up Pete
Post #679579 5th Dec 2023 11:52pm
JayGee
Parts supply issues was the reason I made it as the car would have been stuck at the garage for weeks if not months waiting for stock. The end that goes into the housing is a push and clip fit so may not be universal but I'm sure gluing one in there with epoxy would do the job. The thermostat housing below also fell apart when it was removed but the garage was luckily able to source that. The black plastic on these cars is not aging well...... 2012 TDV8 Vogue (L322)
Post #679600 6th Dec 2023 9:43am
