Home > Technical (L322) > Suspension question
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
Suspension question
Hi all
Looking for a yes or no answer if possible….the rear drops overnight am I right in thinking that if I remove the relay for the suspension in the boot and it drops then there is an air leak somewhere ?
Thanks L405 2014 Loire blue Autobiography
Post #680379 15th Dec 2023 1:04pm
dhallworth
The relay in the boot is for the compressor. I don’t believe it will remove power to the ECU.
Easiest thing to do is park it up and take the positive terminal off the battery. If your height changes then, it’s definitely a leak.
Post #680386 15th Dec 2023 2:58pm
will308f
yea think i do that this weekend ,ive also got a rear valve block to fit (new rubber seals and voss connectors fitted ) Thumbs Up L405 2014 Loire blue Autobiography
Post #680398 15th Dec 2023 4:07pm
