![]() | Home > Maintenance & Mods (L322) > Recommended Antifreeze - 4.4 TDV8 |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
https://www.advancedfactors.co.uk/service-...-168-c.asp
| M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165
Thanks Rob. If I can't find something local that'll do nicely.
Halfords website says silicate free OAT for the 4.4
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
Manual says Texaco (Havoline) XLC Coolant
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3888
I bought a litre of Castrol SF from Opie a couple of years ago, but it is still unopened.
If I'm topping up is is ok to mix types/brands?
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
Any pink OAT coolant will do fine. Not had to top up the 4.4, but swapped it all out on the 3.6 for the euro car parts stuff.
Pink OAT only with no silicone. I favour ready made stuff Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
And by pink do you guys mean RED ?
Might have slightly over filled it.. |
I would if it were me Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
| Mfcetin Member Since: 26 Jun 2023 Location: Nürnberg Posts: 69
My coolant level is a little low so on cold start I get low coolant level warning which goes away once engine warms up a little. I ordered Castrol SF as the handbook suggests to op it up a little.
| lschwarcz Member Since: 18 May 2019 Location: Hillsboro, OR, USA Posts: 276
I just had to top-off my 2009 L322 Autobiography and the local dealer was out of stock. He told me that it's now $65/gallon. That's USD and a US gallon. OUCH! But, he told me that it's just Dexcool that I could buy at most auto parts stores. I picked up a gallon at my local store for $19. And yes, it's orange! I can't say that this'll work in your L322 but this is what I was told I could use in mine. Good luck! Larry. 2009 Range Rover L322 Autobiography Bournville/Ivory Save lives, give blood. |
