![]() | Home > Technical (L322) > "Suspension fault" on dash display |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
Impossible to say with certainty but if the heights were fine and no other visual problems then I'd use it...
Squirrel Member Since: 15 May 2012 Location: Reading Posts: 212 ![]() ![]() ![]() |
I’ve got it home now, when it’s parked on the sloping drive the offside is up, the n/s front is hissing and the n/s rear is on its bump stops, so it looks as though it’s popped its suspension airbag on the nearside.
Too thin and too much pressure to fix it in situ, possibly could if you take it off but you might as well change it then...!!
It's 170 miles there and back, a bit far for the dogs. |
The compressor will be running all the time to cope with the hole...
Yeah, that’s what I thought. I don’t need to use it, I’ve got another car I can use until it’s fixed.
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 703 ![]() ![]() ![]() |
Hi,
Sorry typo, it held out till I got to the stealers 20 miles away not 2.
