![]() | Home > Technical (L322) > Suspenssion high on the front |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7967 ![]() ![]() ![]() |
Is the graphic on the 4x4 info screen showing the front as high?
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
They did disconnect the battery whilst welding, I assume... 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
Thanks mjdronfield
Paul H Member Since: 17 Oct 2023 Location: coventry Posts: 85 ![]() ![]() ![]() |
after I swopped the front struts and ride height sensor I recalibrated mine (10 mins using the latest IID tool) not sure on the older ones. Worth a try? 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea! |
