![]() | Home > Technical (L322) > Old Towbar removed - is this OK? |
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 407 ![]() ![]() ![]() |
Hi All,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35861 ![]() ![]() |
not familiar with this one but it does look like you need something put back in its place... |
I would suggest mabe disconnecting the electronic cable and maybe putting it all in the shed or garage. In its current state will make a hell of a noise and probably do a lot of damage should you try and drive with it hanging under the car like that @ 70mph. Just a thought. |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
Thats a non genuine towbar , but it looks like you are missing the supports that bolt were the brkts you have now go the ones with the tow eye attached have a look at a car with out a tow bar and youll see what i mean onto no6 Range Rover
heres a pic of my bottom which shows the oe towbar ..obviously you havnt got this but you should have something there in its place..
Cheers all for the quick reply's.
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1529 ![]() ![]() |
No problem!
superspoons , a bit of black metal paint could be an good idea under there... |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2075 ![]() ![]() ![]() |
Can't see the bumper support / towing eye brackets |
The bumper is rock solid and I can't see where extra supports would go...The angle iron each side of the tow bar I've just removed are holding the bumper in place
Sold my Swan neck, but have the removeable Fixed plate version available |
