![]() | Home > Technical (L322) > 3.6 TDV8 mk3 (2010) restricted performance. Advice Needed |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 379 ![]() ![]() ![]() |
Check voltage with engine running should be circa 14 volts this should indicate if alternator is issue ie not charging the battery. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Blinche Member Since: 29 Dec 2023 Location: Caen Posts: 9 ![]() ![]() ![]() |
Actually based on the gap IIDtool it is around 14v
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 189 ![]() ![]() ![]() |
check pending errors |
Jimmie
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
When you checked the voltage was that with the cruise control switched on? John
default setting in iid is to show only stored errors. You can select lot more. If you turn on to show pending errors, then you get lot of not active, but occured just once. It can show you additional symptoms. |
Ah ok i didn’t know
Hello
yes. Can it be. |
Ok
Hi all
Alléluia
Apps Member Since: 24 Dec 2024 Location: Leeds Posts: 23 ![]() ![]() ![]() |
What sensors did you end up changing as I'm having the same issues |
Hello
