![]() | Home > Technical (L322) > Alternator not charging |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 381 ![]() ![]() ![]() |
Check your earth connections are ok can’t remember if it’s the 322 or 405 but one has a earth strap behind a front wheel liner that corrodes. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 508 ![]() ![]() ![]() |
Hi,
Kiwi_V8 Member Since: 16 Aug 2014 Location: Auckland Posts: 37 ![]() ![]() ![]() |
So, it’s been checked over, earths were all good (thanks for the heads up), put back together and is working.
timse Member Since: 06 Dec 2019 Location: Farnborough Posts: 37 ![]() ![]() ![]() |
I bought a cigarette lighter volt meter and keep it plugged in. Really handy to just look down and check what the voltage is. |
So, to close this one off, after a fair bit of investigation the new alternator was identified as being suspect.
Tiny Timmy Member Since: 04 Sep 2013 Location: Bucks Posts: 215 ![]() ![]() |
Good idea I've ordered mine ...thanks... ![]() |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1007 ![]() ![]() ![]() |
I ordered one a few days ago ( using Amazon ) and it arrived this morning, I plugged it in and my reading is only 12v, should I be worried, the car starts ok on the button MY11 (does not need a key) its push start ! |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3334 ![]() ![]() ![]() |
12v is nothing to worry about. You can also monitor it via the secret touchscreen menu. The battery monitoring system is pretty sophisticated and will tell you if anything is wrong with the charging system. 2012 TDV8 Vogue (L322) |
Mine reads 12v until you start the engine. It then goes to 14.6 or 14.7v depending on how long since last driven |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291 ![]() ![]() ![]() |
Thought we only had that in France...had my alternator replaced 4 weeks ago 600 euro and same problem. New one was not up to it's job. Seems that garages are all the same, they put in some sh...y new part that cost them small money and the "patient" wont check. If it works it's fine and they make good money. If it doesn't work they will discuss and tell you it's not their fault, some wiring problem, or what ever. Took some "convincing" but they replaced it with decent one. Now it's fine |
