![]() | Home > Technical (L322) > 2007 TDV8 Plagued with electrical issues |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826
I take it the battery and alternator are fine and working well...?? Pete
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3350
Battery seems to be holding a charge well without the voltage dropping. Alternator seems to be charging properly as well from what I can test with a multimeter.
Oh well, would have been an easy fix...!!
| dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1422
Abs sensor gone bad just need to find which wheel is the A sensor, at a best guess. |
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1891
P0500-00 gets logged with a faulty ABS sensor/ABS ring as above
Thanks guys,
Finally got a chance to have a look at my friends car today.
Finally managed to replace this ABS sensor last night.
I know you probably have done this, but make sure the sensor you replaced is the proper part, they change from front to back and diesel to petrol, a resistance check should tell you which sensor it is... |
This is the sensor that was fitted to the car:
Wiring diagram found for the ABS |
I've just checked the resistance of all the ABS sensors at the plug for the ECU.
| andyrosehome Member Since: 06 Jan 2018 Location: South Wales Posts: 26
Did the Eurocarparts sensor cure the faults? |
Sorry, I didn’t get a notification that you’d replied.
