![]() | Home > Technical (L322) > Hill dissent |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4350 ![]() ![]() ![]() |
Worth having the codes read by a good independent specialist as a start. That may give you clue as to what is going on. There is one in Tavistock but forget the name....
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 703 ![]() ![]() ![]() |
Hi, Not sure if this is something, but I was just setting off one day when the car came to a sudden stop.
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 603 ![]() ![]() ![]() |
When I get home I’ll scan (gap tool) ,nothing been split maybe a sticky button,and if the wife had just set off I would of gone with the handbag but she had been out and about for 30-40 mins driving so I don’t know but like you said scary L405 2014 Loire blue Autobiography |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1412 ![]() ![]() |
Give him a yellow card 😂 |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 804 ![]() ![]() ![]() |
As Andy Roo has said - either the HDC button has been pressed inadvertently (easily done when placing things on the centre console) or perhaps the mode button has been pressed in a similar manner and the car goes into Grass/Gravel/Snow which switches on HDC automatically. Simple answer is to leave the kitchen chains shackled and not let her drive the car...... |
Hi, shame you can't just plug the wife in when you need her.
I strongly suspect a heavy handbag..... ![]() ![]() |
right been out and scanned but there was no faults showing for the hdc or terrain response |
