Home > Maintenance & Mods (L322) > Handbrake being a bit arsey
GGDR
Hi team
I am doing my rear pads today, rotors are ok so hadn't planned to take them off... but maybe I shoudll because I am getting handbrake fault messages more and more.
Had a bit of a search around, can't see a typical thing to look for.
Any tips?
Many thanks. Cheers, Greg
Post #683390 21st Jan 2024 10:40am
JCW
Only takes a small amount of extra effort to back off the handbrake shoes adjuster and remove the locating screw to remove the brakes discs (rotors??) and inspect inside, often the shoe retaining pins / springs / pivots are in poor condition and may need cleaning or replacing.
If the adjuster doesn’t back the shoes off relatively easily and/or the brake discs put up a fight when trying to remove them (e.g. they’re heavily lipped) that likely indicates an issue that you’d need to deal with anyway Thumbs Up Jonathan
2010 L322 5.0 SC Autobiography Black
2007 Defender 90 XS Hardtop
Post #683393 21st Jan 2024 11:17am
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
As JCW says, it’s worth the extra effort to whip the discs off and check the handbrake, the retaining pins and clips have a habit of rusting so a good clean up and some carefully applied grease should sort it out.
Post #683402 21st Jan 2024 12:01pm
JayGee
Re: Handbrake being a bit arsey
GGDR wrote:
Hi team
Any tips?
Many thanks.
If it's just the flashing handbrake symbol on the dash then don't worry as this is common and seems to be cause by the suspension adjusting itself when parked for a long time / overnight.
BTW you should realy change pads and disks at the same time and not put new pads on old disks esp at the rear as they don't apply much braking force and if rust gets hold on the unbraked area it will spread. 2012 TDV8 Vogue (L322)
Post #683403 21st Jan 2024 12:02pm
GGDR
Thanks JayGee, Jools & JCW
Before the storm hit I got the new Greenstuff pads on, big tick. The wear sensor is a bit of a pain but it's too.
Onto the handbrake:
With the rotor (disc) off I found the shoes assembly especially on the Offside was very rigid so I cleaned up the area, carefully applied grease to the moving bits and reassembled.
The handbrake is no better, maybe worse now. It goes on fine, the error occurs on trying to release.
Got my MOT this week so a bit twitchy now... Cheers, Greg
Post #683444 21st Jan 2024 6:38pm
GGDR
Interestingly, U2002-92 points to the switch
The manual confirms is the switch in the cabin
Anyone know easiest way to get the switch out of the console?
I must admit I'm a bit skeptical because the handbrake actives fine and I can hear a zippy sound from the rear every time. It's faulting on release of the EPB
If I'd spilt a coffee I'd tend to agree with the workshop manual but no drinks have escaped any time.
Anyone have experience of this?
 Cheers, Greg
Post #683447 21st Jan 2024 7:04pm
GGDR
day before MOT:
behaving, behaving behaving
morning before 9am MOT: faulting again
Then
MOT passed!
PHEW
Replacement switch arrived yesterday, to try next but I need to roll the MOT dice first as I had a booking.
Any tips on how to get the switch out? Cheers, Greg
Post #684052 27th Jan 2024 7:16pm
