Home > Technical (L322) > Rear passenger lighter socket |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34918 |
is it not in the glove box fuse array.. |
2nd Aug 2011 12:56pm |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 |
Not that I can find (the only one that mentioned a lighter socket had an intact fuse) !
2nd Aug 2011 1:40pm |
I believe the lighter sockets are both fed from the same fuse, they are not designed to be used for anything other than the cigarette lighter. If your front socket is working but rear not, then perhaps someone plugged something other than the lighter into it and it/the wiring is damaged?
2nd Aug 2011 3:11pm |
They're on a pair of 20 amp regular fuses on my 2007 VSE. main one and one of the rears is on one fuse and the on iside the cubby plus the other in the back of the console is on the other. Boot socket is on its own fuse. |
2nd Aug 2011 6:18pm |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 |
May be a daft question. Have you tried the lighter from the front in the rear socket? Sometimes lighter itself plug actually fails. No longer FF owner but still interested. Present car Jaguar XE
2nd Aug 2011 8:59pm |
Ah yes - children with a DVD player on the lighter sockets I'll check the actual DVD current draw, but I would expect it to be a lot less than the actual lighter ! The one inside the cubby appears to be off too - so I'll have a dig around the rear fuse box too this evening - thanks. |
3rd Aug 2011 8:39am |
Perhaps its prolonged current they dont like? |
3rd Aug 2011 8:41am |
Sadly all of the front & rear fuses are fine - so a cubby box stripdown is scheduled for this weekend ... |
4th Aug 2011 11:42am |
