Home > Technical (L322) > 4.4 tdv8 intermittent wheel sensor fault code
Downhillerffrr
Replaced the rear left wheel speed sensor after multiple faults and that was the only fault that wouldn’t clear (C0037). Fault didn’t reappear for a week. Now it’s started again. Checked the connector under the wheel arch and that’s fine. C0037 25(ECool rear right wheel speed sensor general signal failure signal shape/waveform failure. Any experience on here of what this may be ? Known chafing point in the wiring somewhere ?
Post #683753 24th Jan 2024 11:00am
JayGee
Check the integrity of the trigger wheel on the hub - loose, missing teeth due to corrosion or misaligned. 2012 TDV8 Vogue (L322)
Post #683757 24th Jan 2024 11:09am
Downhillerffrr
I’m liking that diagnosis. Would make sense. I’ll let you know once I’ve taken it apart
Post #683808 24th Jan 2024 8:57pm
Downhillerffrr
Ring looks fine and intact. I cleaned out the sensor hole a bit more. Seemed fine for a short drive and now it’s started again with the new sensor. IID tool shows that wheel at zero mph whilst the others show normal when in fault mode. It sometimes resets with no faults. Cleaned up the connector under the arch in case it’s that. Fingers crossed but I think it may be an intermittent wiring fault.
Post #684047 27th Jan 2024 5:41pm
Epson Green
The ring can indeed look intact but can also be off the shaft and corroded onto the inside of the knuckle!
Did you rotate the shaft when looking at the ring?
 Kevin
2012 L322 Westminster 4.4 TDV8
1999 P38A 4.0 SE - Sold
Post #684097 28th Jan 2024 11:06am
Downhillerffrr
I spun the hub and it was normal. As in it was attached to the driveshaft and looked in good condition. I’ve given the connector another good clean. Since then the multi faults including the left rear abs sensor have not returned. However , it did go into Adaptive Suspension fault in the front left. This is due to a broken wire which I have now fixed. I am now wondering if in fact this was the main fault and the breaking wire confused the Canbus into saying the rear left abs sensor was faulty. Interestingly the rear left abs sensor would give a reading that the wheel was going round when the car was parked. This was during the period I was measuring all four wheel speeds simultaneously with the IID.
Post #684412 31st Jan 2024 12:49pm
Downhillerffrr
Fingers crossed. Now that I’ve repaired the damaged wire that feeds the top of the front left shock (Adaptive Suspension) with the Land Rover repair kit this appears to have prevented all of these faults repeating themselves.
Post #684732 4th Feb 2024 5:33pm
