Home > Technical (L405) > Deciphering Fault Codes & Next Steps
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
Hi all, I have an iCarSoft V3 scanner which I use to read fault codes in my RR. This is great but sometimes the descriptions of the fault code can be a little short or unclear. What are people using to get more expanded info on error codes? Basically how can you work out which fault code is the actually cause of an error and which fault codes are related to an error but are not really faults? Do I need to have a Topix subscription to do this? Can you enter a fault code in Topix and will it give you more information such as what the next diagnostic steps should be or which parts are likely need to be replaced? Or is it simply just a case of Googling the codes? Wink
Post #684039 27th Jan 2024 4:27pm
Kot
I used Topix for a few days and downloaded everything from workshop manual for my VIN, there is a section with DTC codes. 2018 SE SDV8 4.4 Byron Blue
Post #684057 27th Jan 2024 7:47pm
ReggieMac
I am thinking i need to put a day aside and do this with Topix. Do you know if the fault code lookup provides additional steps to try to help identify exactly where a fault is, a bi like a check sheet? I have seen something similar online but I think this related to JLR SDD software. Would Topix have the same
info does anyone know before I invest in a short subscription?
Post #684108 28th Jan 2024 1:05pm
Kot
Yes
See this as an example
Post #684118 28th Jan 2024 3:12pm
ReggieMac
Excellent, thank you Kot that is very helpful Very Happy One further question, what section did you have to subscribe to in Topix to have this access? Is it just the 'Diagnostic' category?
Post #684126 28th Jan 2024 5:27pm
Kot
Sorry cant remember it was a couple of years ago 2018 SE SDV8 4.4 Byron Blue
Post #684165 28th Jan 2024 11:14pm
ReggieMac
No worries, thanks for your help anyway. I will buy a 24 hour subscription and see what I get in the 'Diagnostics' category, hopefully wont be a waste of money! Laughing
Post #684218 29th Jan 2024 1:33pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
If you download the WSM from the wiki and look in the General Information section and then Diagnostic Trouble Codes, they are all listed.
Save yourself a few quid! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #684231 29th Jan 2024 5:20pm
ReggieMac
Aha, thank you 4RRS I never gave that a thought, just the job! Bow down
Post #684239 29th Jan 2024 6:45pm
