Home > Technical (L322) > Supercharger Service/ReBuild
dan_uk_1984
The superchargers on the 4.2 are a "sealed for life" unit - you know my thoughts on anything sealed for life...
However there is mention (like in the gearbox) of the procedure for changing the oil in the Supercharger itself - it uses different oil to the engine etc so never gets changed.
Some SC's need re-building after 50-60K, however the screw type SC's are generally described as "bullet proof". That being said, I wondered if anyone had further info on the exact type of SC fitted to the AJv8 and even better if someone has the Tech /WSM info about it? Then I can do further research on the thing - which currently I don't know anything about.
Thanks,
Dan
Post #74585 3rd Aug 2011 9:49am
Jonno
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Hi Dan
Try Dennis Priddle - he's the man
http://www.jagweb.com/aj6eng/superchargers.php
Jonno 5.0 supercharged autobiography
Gone-4.4 Vogue Lpg now unmapped
4.6 HSET Turbo Lpg mapped
Gone-Defender 90 200tdi
Gone - 3.9 Sprintex supercharged LPG
Gone - 3.9 Vogue LPG
Post #74589 3rd Aug 2011 10:15am
HUGI
Switzerland 2006 Range Rover Vogue Supercharged Java Black
I thought the 4.2L SC has a Supercharger from the Company Eaton and it is a Roots Supercharger.
Changing Oil is possible and I think it is not so difficult. (I asked this question somewhere but forget where)
check the topix files,there should be something about the oil change for the SC.
Post #74615 3rd Aug 2011 3:06pm
dan_uk_1984
You're not wrong, I thought the 4.2 used the twin screw type but as you say it uses the Roots "Blower" which is a relatively basic type.
Post #74617 3rd Aug 2011 3:24pm
dan_uk_1984
OK, to answer my own question, they are filled for "the life of the vehicle" but don't declare what the life of the vehicle is - typically though manufacturers suggest 100,000 miles.
What Eaton do say is:
If your vehicle has an abnormally heavy duty cycle, such as racing or towing, you could consider changing the oil at regular intervals such as 20k, 30k, 50k, or 100k miles depending on usage.
Which suggests if you want extended life, an oil change may be a good idea - I would gues at a minimum of every 100K for everyday use but maybe every 50K if you tow with it?
Post #74626 3rd Aug 2011 4:27pm
