Home > Technical (L322) > Blown mega fuse again
Clarky595
England 2008 Range Rover Vogue TDV8 Java Black
Hi guys the Tdv8 is playing up again it has blown the mega fuse and I replaced it with a new one and went to start her today and it’s blown again …..Any ideas I was thinking maybe a bad earth lead as the starter was replaced last week and the earth in the drivers wheel arch got disturbed by the fitter but not sure if this would cause it to blow any help much appreciated as need the old girl up and running as the long haired general has a horse show at the weekend.
Post #684247 29th Jan 2024 8:23pm
if it was ok before the new starter then thats the obvious place to look first.. ... - .- -.
Post #684263 29th Jan 2024 10:13pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Fuses don't usually blow with an earth lead not grounding correctly, if anything nothing would happen as the loop would be open circuit, you might get the click of the solenoid, but the starter wouldn't throw.
More likely something wrong on the positive side of the starter, either an intermittant fault within the starter itself or the positive side shorting to earth externally, i.e. connector.
Make sure that the starter connectors are all clean and nothing is going to ground that shouldn't be.
If that's all good, start looking for signs of water around the main fuse box and starter relays.
Don't be tempted to fit a bigger fuse, you could start a fire and destroy your car, not to mention potential damage to yourself. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #684267 29th Jan 2024 10:23pm
Eastsoutheast
United Kingdom 2012 Range Rover Vogue TDV8 Santorini Black
+1 to check starter motor as most likely culprit. Good luck 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #684268 29th Jan 2024 10:23pm
Clarky595
After the new starter was fitted it still wouldn’t start and was told to check mega fuse and replaced the fuse and bingo she started .But went to fire her up today and click …..
Post #684272 29th Jan 2024 10:58pm
