Home > Technical (L322) > Coolant loss
Jorrocks
United Kingdom 2018 Range Rover Autobiography SDV8 Montalcino Red
Coolant loss
Afternoon all,
Just got our 3.6 TDV8 back from having the sills welded but now the old girl has just told me the coolant level is low. I topped it up hot (The level was a bit over an inch below the lower cold fill line). The warning came on again about 100 miles later last night, and a similar amount more was added to the tank by my wife who was driving it.
This morning I took a quick look under the front of the car and could see a coolant drip from the front skid plate on the nearside. It is almost exactly in line with the power steering reservoir. Would that give you chaps an idea as to the likely culprit for the leak?
BTW, the level cold is currently half an inch over the lower fill line.
Many thanks in advance!
J
Post #684520 1st Feb 2024 1:23pm
Jorrocks
I’m going to bite the bullet and have a rummage under the car tomorrow to see if I can locate the source of coolant leak.
Assuming I locate and fix said leak, how can I ensure that I flush out ALL the remaining coolant? I hadn’t realised that so much remains in the system during a normal drain, and now I’ve bought new I really don’t want to mix different brands (And the colour may not be aesthetically pleasing!😄)
Will flushing with constant running water do the trick eventually, or could I do a couple of water-only fill and drain cycles with engine idling each time?
Post #685201 9th Feb 2024 5:14pm
Bennyis01
England 2010 Range Rover Vogue SE TDV8 Zambezi Silver
Hi bud had exactly the same, I would top up the coolent bottle and drive it without any problems,leave it overnight and levels would drop. Took it garage and they pointed to pipe in wing . I'm assuming drivers side near the bottle. Goodluck
Post #685323 11th Feb 2024 8:15am
Jorrocks
Hey,
Thank you for taking the time to reply! I think I’ve located the source to the cluster of stuff around the heater control valve on the nearside wing. 2018 L405 4.4 SDV8 Autobiography
2010 L322 3.6 TDV8 Vogue SE, 171000 miles and counting….
Post #685402 11th Feb 2024 10:36pm
