Home > Technical (L322) > Where is my coolant leaking from, any ideas?
Jorrocks
United Kingdom 2018 Range Rover Autobiography SDV8 Montalcino Red
I have got a coolant leak which I am having trouble locating. I took off all the under trays in order to get a better view and I can now see it dripping but I don’t know which component has failed. I am hoping one of you may have experienced something similar.
This is a 2010 3.6 TDV8.
I have taken a few photos, but the leak seems to coming from the passenger side (RHD) of the engine bay between the exhaust manifold heatshield and the body. Any ideas?
 2018 L405 4.4 SDV8 Autobiography
2010 L322 3.6 TDV8 Vogue SE, 171000 miles and counting….
Post #685275 10th Feb 2024 5:53pm
Tdtj
Unsure if the 3.6 is the same coolant pipe wise but my 4.4 l322 had stainless pipes running down the n/s just above the chassis a several pin holes appear under pressure and leaks. There is a post somewhere on here if you do a search and replacement advice and cost Big Cry 2016 4.4 diesel
Post #685300 10th Feb 2024 11:00pm
Jorrocks
Thanks! Yikes, I think you’re correct. £700 for that part is a complete p***take. I can get a fabricator to make me a copy for about a quarter of that. Then there’s the question of why JLR designed a part for the cooling system that isn’t resistant to coolant🤬🤬! 2018 L405 4.4 SDV8 Autobiography
Post #685403 11th Feb 2024 10:43pm
Tdtj
If you search further you will see that someone repaired there’s with a length of rubber hose. Which is exactly how I did mine. Bought about a three metre length,used less than a quarter of a metre. But fixed the leak all the same Thumbs Up 2016 4.4 diesel
Post #685405 11th Feb 2024 10:51pm
