Home > Technical (L405) > Front Air strut leaking at the Top
RRL405Ger
Germany
Hello,
my right Air strut in the front is leaking very slightly, but it´s leaking.
It take several hours, at least 8, to depressurize the front.
Is there any chance to reseal it? I would like to avoid changing the whole strut just because of this small leak.
I marked the area in the attached picture where the air is escaping.
Already thinking of using (windshield) glue or something similar and put it in between the top. Just to see if this will seal. Or if applying more torque on the nut will result in a sealing o-ring underneath?
If not, I could still by an bag or even the whole strut.
Had anybody of you already this issue and tried it?
Post #685392 11th Feb 2024 9:49pm
