![]() | Home > Technical (L322) > Front suspension won't lower |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 799 ![]() ![]() ![]() |
Sounds like a faulty height sensor. The older I get, the more I realise that people confuse wrinkles for wisdom |
Spongo Member Since: 13 Sep 2022 Location: Doncaster Posts: 7 ![]() ![]() ![]() |
Update, I have done all the O rings in the front valve block, still the same. Height sensors appear to be working when checking using GAP tool.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
The workshop manual is in the Wiki for download, top right, under the fullfatrr banner.
Thanks for that, I do have the workshop manual but alas it doesn't describe what happens to each valve etc. I think its fairly intuative, seems strange that its only the front that "sticks", to me if seems like a sticking valve but these cars can be fickle.
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 589 ![]() ![]() ![]() |
Sounds like valve block could be sticking ,have you tried swapping the front and rear valve blocks around to see what happens ?.if the front then lowers and the rear doesn’t then you know it’s a valve block issue……you can pick them up from eBay (£15 ish) |
Now why didn't i think of that |
Well after a few hours tinkering in the garage I solved the issue.
I was going to mention the exhaust on the air compressor, but as you said the rear lowered I didn’t think it was that. Nothing lowered when mine was blocked.
