Home > Maintenance & Mods (L322) > Engine oils
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Engine oils
Was thinking about C1 oils
I live on south coast…I don’t really need a 5w on cold morning and was thinking of using a 10w40 instead of the 5w30
And then i found this:
https://www.mymotorworld.com/citron/c1-pm-...FbEALw_wcB
Any thoughts on this 5w40 ?
Post #686349 24th Feb 2024 2:13pm
JMC
SPECIFICATION - ACEA A3/B4-16
This is not a C1 specification oil. It's meant for a Citroen C1.... Rolling with laughter
The 4.4 TDV8 needs a very specific oil for a reason. I would urge you not to skimp on it.
This is a good economical choice:
https://www.smithandallan.com/product/smit...e-oil-4127 The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #686352 24th Feb 2024 3:07pm
Mikey
If JLR said 5w40 was suitable, they'd list it as a compatible oil
They don't, it needs 5w30 C1 spec Thumbs Up
Post #686353 24th Feb 2024 3:12pm
Rambles
Haha Citroen C1 not oil C1
Maybe too early for April 1
Laughing
Post #686359 24th Feb 2024 3:43pm
garyRR
As above, the Smith & Allan or I can also recommend Petronas 5000 FJ.
Specification has to be 5W-30 ACEA C1 WSS-M2C934-B STJLR.03.5005.
Don't skimp on oil filter - the original OEM is Mahle OX153/7D2 and is only a few quid more than cheapies. 2015 Range Rover Autobiography 4.4 SDV8
Post #686387 25th Feb 2024 12:05am
