![]() | Home > Technical (L322) > Blind Spot Assist retrofit help please! |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3329 ![]() ![]() ![]() |
Are you sure you have the blind spot monitoring lights in the mirrors? If so, are they connected?
flashheart59 Member Since: 27 Jul 2013 Location: Essex Posts: 26 ![]() ![]() ![]() |
Thanks for the thoughts. I’m sure I’ve got the right mirrors, with the little symbols, it’s what made me want to do this.
Paul H Member Since: 17 Oct 2023 Location: coventry Posts: 87 ![]() ![]() ![]() |
Apologies if I am reading this wrong but are you expecting to being able to enable blindspot monitoring based on having the right mirrors?
Mirrors fitted from new, I’ve just added blind spot sensors behind rear bumper and activated with IId tool. I thought that would be it but seems there’s more to be done….. |
found this on another site and it seems you have done all the necessary but need the full CCF on the iID tool to enable side object detection?
Thanks Paul, much appreciated, I’ve got the full IId access. Can only think the sensors are wrong as I believe there are two different engineering numbers for the sensors, maybe early and late. Just seems odd to have no fault codes or any lights illuminated on the mirrors. |
