![]() | Home > Technical (L322) > TSB LTB00409v4 - 5.0L Engine Misfires /Check Engine Light On |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 419 ![]() ![]() ![]() |
Here you go: -
winco Member Since: 12 Feb 2024 Location: Dorset Posts: 48 ![]() ![]() |
Thank you @4RRS.
I would imagine so, check with Patrick at GAP, think the flash file cost is £35. I assume you scanned the ecu's and IID show an update is available? L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
I dont have GAP IID yet, I am using JLR SDD after having Jaguars for the past 12 years. The TSB notification came up on that along with the reconfiguring of the PCM as a recommendation. However, that is where I stumbled where it would not download the offline files required.
I used to use a 'non official' offline (if you know what I mean) copy of SDD and it used to fail trying to download files in bulk, either for vehicle model or VIN, but if you went into the update routine for whatever ecu you were trying to update it would always download whatever was needed there and then. I'm now using offical SDD as at £35 per file from GAP it was going to get expensive as I wanted all ecu's up to date.
Yes, I know what you mean! It worked when I configured a towbar on my XF. Just this time, it might be more cost effective to ask my local LR indy to mass update.
