![]() | Home > Technical (L322) > Dead radio |
ballast Member Since: 18 Feb 2016 Location: Midlands Posts: 46 ![]() ![]() ![]() |
Try a reset - remove the battery and then connect +ve to -ve on the car. Give it 5 mins or so after you’ve disconnected the battery before you do it. |
Elliott_4.2_2005 Member Since: 14 Jul 2023 Location: Wales Posts: 14 ![]() ![]() |
Thanks, i will give that ago, hopefully that will do the trick! |
