Home > Technical (L322) > Primary Turbo Location
CharlieF322
United Kingdom 2012 Range Rover Westminster TDV8 Baltic Blue
Hey, what side is the primary (small turbo) located on the 4.4 TDV8 from the driver seat point of view (UK RHD Car)?
Thanks
TDV8
Westminster
Baltic Blue
Post #689233 28th Mar 2024 4:20pm
PeteT80
Misread the question
Post #689235 28th Mar 2024 4:33pm
Dtech
England 2011 Range Rover Vogue 4.4 V8 Santorini Black
The primary turbo is on the right hand side. Not sure that it’s the smaller of the two, it looks larger to me, but could be wrong.
Post #689236 28th Mar 2024 4:33pm
JayGee
Right 2012 TDV8 Vogue (L322)
Post #689237 28th Mar 2024 4:33pm
Old-un
United Kingdom 2011 Range Rover Vogue 4.4 V8 Causeway Grey
Is that looking at front or rear of the engine ? RR owner
Post #689240 28th Mar 2024 4:53pm
CharlieF322
Ok thanks guys. Yeah they don’t look any different in terms of casing size.
I’ve just got a faint whine/drown around 1500rpm which I’m trying to source.
Turbos kick in fine, no smoke, tiny whine as they spool up if you don’t have radio on to hear.
Cheers
Post #689243 28th Mar 2024 5:05pm
JayGee
off-side 2012 TDV8 Vogue (L322)
Post #689259 28th Mar 2024 7:31pm
GraemeS
Australia
The primary turbo is the higher capacity of the 2, with the secondary only a fill-in for higher rpm.
Post #689272 28th Mar 2024 8:55pm
pcourtney
The primary is VGT and the secondary is Fixed
Post #696561 20th Jul 2024 7:55pm
Sql
Poland 2007 Range Rover Vogue TDV8 Buckingham Blue
Cheers
Did you ever manage to find out if this slight spool up noise is considered ok for this engine? Mine does that too. 12 4.4 TDV8 Vogue
Nara Bronze / Arabica / Ivory / Piano
07 3.6 TDV8 Vogue
Buckingham Blue / Sand / Piano
Post #708316 5th Jan 2025 1:35am
