Home > Technical (L322) > Airbags Won't Inflate?
dilligaf789
Replaced the old air compressor on a L322 because it was seized and although the replacement is working and giving out good pressure it is not inflating the airbags on the suspension hence it will not rise, I cannot hear any leaks.
Any help would be great please!
Post #689428 30th Mar 2024 5:43pm
JayGee
What model and year is your car. Do you have diagnostic tool like the GAP IID to interrogate the suspension settings and switch between the 2 types of compressor. 2012 TDV8 Vogue (L322)
Post #689435 30th Mar 2024 6:30pm
The suspension will have faulted, the faults will be a hard fault and need clearing with a diagnostic tool before it will work... just fixing the fault doesn't work... Thumbs Up Pete
Post #689444 30th Mar 2024 7:32pm
dilligaf789
It’s a L322 2005 model. Okay I’ll have to get hold of a diagnostic tool then from I guess. I was hoping it was going to work by just replacing the pump…
Post #689448 30th Mar 2024 8:04pm
